I guess you could get an industrial drone and attach the heater to it to control it over IanWhat has Ian done to upset you so much?
Yes, I use one of these: https://www.amazon.co.uk/Monitoring...d=1653047815&sprefix=sonoff+th,aps,139&sr=8-4Is there such a product or could one be made easily ?
I remeber this episode on either Monk or Chicago fire where someone managed to do this and set the heater to set clothes on fire right next to the electric fire. The murderer still got caught despite being hundreds of miles away at the time.
Dont do it OP.
Cool but my Mum has gone anti wifi believing it's bad for her. So is there a powerline lan type of solution ?Yes, I use one of these: https://www.amazon.co.uk/Monitoring-Temperature-Humidity-Compatible-Control/dp/B07TT92V6X/ref=sr_1_4?crid=3MBLNNIG5AMMM&keywords=sonoff+th&qid=1653047815&sprefix=sonoff+th,aps,139&sr=8-4
I can set a minimum temp and a maximum temp and it turns the heater on and off whenever I want. I can also override it and switch it on from a web browser.
lolCool but my Mum has gone anti wifi believing it's bad for her. So is there a powerline lan type of solution ?
Don’t tell her about 5G then.Cool but my Mum has gone anti wifi believing it's bad for her. So is there a powerline lan type of solution ?
Is she an antivaxxerDon’t tell her about 5G then.
What hazard are you thinking of? A relay is just a switch so I'm struggling to think how it'll prevent any form of hazard, but as with most hazards, they aren't a hazard unless you know about them!If you set up a high consumption device such as a heater with an automated on/off switch, you'll need to run it through a relay. This is an actual real life hazard, not a fantasy one.
A lot of these smart plugs are made of chinesium and despite stating high load, probably can't do high sustained load for a long while. A relay is a switch specifically made for high current applications.What hazard are you thinking of? A relay is just a switch so I'm struggling to think how it'll prevent any form of hazard, but as with most hazards, they aren't a hazard unless you know about them!
