Ek supreme Evo - lga1700 ?
26 Aug 2010
Hey
I've got a old block from my x99 rig. Will this block fit the newer sockets. I can't seem to find any info on Google.
13 Mar 2004
Norwich
I have the same block on an X99 board too and looking to use it on an LGA1700 system.
I think we just need this backplate to make it compatible.
And on the EK website, Supremecy is listed.
OP
26 Aug 2010
If you get it and let me know if it works :D
I hope that's the case. Will save a few quid. But I'm also thinking of going crazy with the lighting so I might just buy new.
13 Mar 2004
Norwich
Good to know it will fit though.
I'm waiting on Raptor Lake but been checking also if I need a new block.
Probably going to stick with my Supremacy EVO if it works, going by reviews of the latest blocks it's not far off anyway.
OP
26 Aug 2010
There's only ever a few degrees between blocks. So if it does fit I'll save myself some dosh and use what I have
19 Oct 2004
London
OOOHH - I have an Evo block I was going to sell. i might pick up one of these to make that a bit easier. Would it then fit all previous Intel sockets? Thanks.
5 Mar 2017
Cambridge
Some motherboards would allow previous gen mounting spacing, but I would suggest getting the 1700 kit, just to eliminate any chance of mounting pressure issues.
When I was searching about previous Intel gen blocks and 1700 socket, the description of the EK kit says, basically, to allow compatibility with 1700 socket, and lists the compatible blocks.
Unless cutting very close to thermal limits, pretty much all decent blocks would still perform well.
The only reason I ended up going with the specific one from EK is because I had to start from zero again, and it would match perfectly my GPU block.
But if you already owns the block, don't bother.
