Images of items I have purchased (except trainers)
Tea Drinker
Don
13 Apr 2010
Sunny Sussex
Ready for some fuel cell building.
I recognise all that. I had a FAA and CAA tig welding certificate back in the day.
Tea Drinker
Don
13 Apr 2010
Sunny Sussex
Check you out! I have YouTube and the certified welders at work guiding me :D
What power control have you got, foot or torch. I could never get on with foot.
Immaculately clean your material including the rods.
Grinder disc dust causes contamination.
If it’s cold pre heat the material with a hair dryer. Makes it easier to weld
Interested to know how it goes
18 Mar 2012
Eastbourne
I’ve got both, I like the foot control, took a while to get used to it though.
Yeah I’ve noticed how much of a difference it makes.
I’ve got a bench grinder out of the way specifically for aluminium now to stop contamination with steel too.
It’s getting there, probably only 4-5 hours of actual TIG welding time, can MIG weld.
Tea Drinker
Don
13 Apr 2010
Sunny Sussex
Looks good, truth is the underside of its meshed together.
If we wanted something tasty we’d use a piece of angle and g clamps then rest the ceramic on the torch on that. You’ll get a perfect line then and all you need to concentrate on is power, speed and rod.
2 Feb 2010
East Midlands
Looks like it records at 1600x1200 in 4:3 aspect ratio rather than a 'traditional' 1920x1080 in 16:9 aspect.
Ah yes, that'll be it. I did notice it uses a 4:3 ratio. I guess makes sense for a doorbell.
Chose this model as no annoying subscription to record video required.
Will fit it tonight hopefully.
mrk
mrk
Man of Honour
18 Oct 2002
South Coast
Upgrade from the old Erisin quad core nav unit to the new Avin 6-core unit and some additional extras (DSP upgrade, i-bus features). Can't wait to swap out the old. New one is near 1:1 to OEM styling too now.
