Microphone Advise
OP
21 May 2018
Caerphilly
Wasn't there issues with the Wave mics being so light and not having enough weight to use a normal arm with thus meaning you need to use their own mic arm?
I believe it was with the Rode Arm. The Wave needed a shock and pop filter to add weight.
24 Sep 2020
Nott'm
I know the Elgato arm comes with a weight just in case you have a fairly light microphone.
But also looking online the Wave 1 apparently weighs more than my AT2020, kind of surprising since I think the AT2020 is a bit of a hefty boy.
4 Feb 2007
Nuneaton, UK
I'm also looking for a mic, I think I'm going to go for the Rode Podmic with an Elgato Wave XLR. I'm hoping there will be some good offers on Black Friday.
24 Sep 2020
Nott'm
Great mic for £100 (not including the Wave XLR) and hopefully it goes on a even more bargain price for Black Friday (I reckon it might go down to roughly £70 if you're lucky).
Not seen too much on the Wave XLR, I watched on quick video and it looks decent as it uses the same program as the Wave mics.
24 Sep 2020
Nott'm
@Mr G I purchased the InnoGear arm thats £38. Quality arm, its actually pretty long (there is a smaller version) and its sturdy as ****. It started off pretty stiff but has loosened a bit over the last few days. Would recommend this arm, seems to be the same as the Rode PSA1 but half the price.
14 Nov 2021
UK
Currently am using a 2nd hand Blue Yeti, its good but very sensitive. At the moment am waiting for Black Friday to bag me one of those rode boom arm and shock mount as this mic can hear my keystrokes.
24 Sep 2020
Nott'm
If the Rode arm doesnt go on offer, I would recommend this one its a similar design and its really good. And its half the price of the Rode one anyway.
19 Apr 2012
Mr G, Did you buy the Wave 1? If so, How are you getting on with it? I'm currently looking at buying a Wave 3, Someone locally is selling one with a boom arm for £80.
4 Oct 2019
Belfast
There's also the Yeti Nano. I've been using the larger Yeti Blue though and the sound quality has been amazing. It's very sensitive though so I had to use it with Nvidia's Broadcast app since Discord's Krisp wasn't doing a good job filtering out unneeded noise (eg when I use my keyboard, outside traffic, etc).
I had this too.
