it's 4wd drive, google suggests a navara(?) has 7 speeds, isn't 50-55mph in 6th more efficient - given their target use, optimising the gearing for dual/motorway speeds sounds odd ?
This gets very complicated - the Navara is not full-time 4WD it is rear-wheel drive for road use. There are (in the UK) essentially two variants of the D40 - the 2.5L V6 which is designed as a workhorse and the 3.0L V6 (V9X) like mine which were designed as "lifestyle" vehicles (with fancy seats and a Bose premium sound system, etc. heh - so not your typical builders truck).
The 2.5L behaves like you are saying, the V9X is a "luxury SUV" engine and uses transmission and electronics based off (but not the same as) what is in the 370Z - it uses silly software tricks and different gear profiles low vs high to try and combine the best of both worlds and while it mostly works isn't flawless - for instance if I get stuck behind a cyclist power delivery becomes very bursty
Then it gets all different again for the older and newer models than the D40.
