RBG/ARGB connectors
24 May 2010
Birmingham
Hey, I have gammax GT RGB cooler and unsure where to put the RGB cables, only one of the cables fits into the RGB header but the cooler and the fan also light up so wouldnt I need to plug another one in? I have a controller but its 3 pin for the ARGB fans at the front.
Also is it safe to use both the 4 pin RGB header for cooler and Jrainbow for the 3pin argb controller?
Sorry, first time building I'll try get pictures when I can.
5 Mar 2017
Cambridge
Totally fine. The only issue, if one can call it an issue, is that the 4 pin RGB won’t be able to replicate the effects of the 3 pin ARGB. But if you use static colour, doable.
