Hi
I'm looking to build a mini PC for controlling a telescope and doing some astrophotography.
I considered using a Raspberry PI - but they are difficult to get hold of, and subsequently, are priced higher that I'd like since I'd have to jump through a few hoops to install Windows on it.
Are there any mini factor motherboards (AMD or Intel) that can be powered via a USB (5 volts) cable (just like a Raspberry PI)?
I want to keep the PC as light-weight as possible - 2/4 GB RAM. Low power CPU.
Any thoughts? Am I stuck with going down the PI route?
Thanks
Sat
Thanks
Sat
