Zen+ and X570S?
9 Oct 2018
Folkestone
What happens if I put a Ryzen 5 2600 in a X570S Aurous Master?
Now clearly I know I am not going to get PCi-e 4. But the Motherboard specs are a bit unclear about exactly what I will get from the PCi-e/M.2 slots when a Zen+ CPU installed.
But will the M.2 slots just work at PCi-e 3 speeds or will they not work at all?
And for the USBs - will they function just at a slower speed?
Finally what are my chances of getting better memory clock speeds and timings? I know the CPU is the main factor, but topology plays a part too, and that has improved significantly from B350->X570S.
I have really good DDR4 RAM (Team Group RIPPED Edition DDR4 PC4-28800C14 3600MHz) but the best I could get with my 2600 is 34000Mhz - it doesn't POST with XMP.
I'm asking because I don't have the budget to buy a MOBO and a CPU at the same time. While Ryzen 5000 processors will be available for some time at a gradually reducing price - and second hand after that - motherboards have a habit of holding thier price and then suddenly going out of stock and not returning.
So because of that, grabbing a MOBO first seems more sensible.
*My motherboard options are quite limited by the fact that I refuse to consider downgrading in any way and many of the most recent AM4 motherboards - especially from MSI - have elected to go with Realtek LAN. I want to stick with AM4 because I already have really good DDR4 RAM. USB ports are important to me for outside-in VR tracking and M.2 ports are important to me as that is the way storage is going - hence the X570S Aorus Master.
OP
9 Oct 2018
Folkestone
What worries me is this line about 5000/3000 only for the Chipset M.2
Whereas for the CPU M.2 it explicitly states previous gen CPUs are supported at 3.0 speeds
11 Oct 2009
Greater London
22 Jun 2006
The manual is a bit easier to read than the specs page, but it appears to work just like Orcvader said.
About the USB ports, I think you'll still have them all. The CPU derived USB ports are still supported by Zen+ and the other ports are either from the chipset, or an ASMedia chip.
